Unfortunately, IPv6 has disappeared yet again.
At this point I’m no longer just frustrated by the intermittent IPv6 service. I’m frustrated that nobody seems able to say with any confidence what the actual problem is.
Is it the network? Is it the gateway? Is it a firmware bug? Is it a configuration issue? Depending on who you ask, the answer seems to change.
The supplied gateway has, in my experience, significant limitations, so it’s easy to suspect the hardware. Equally, this could be a network-side issue. The point is that I shouldn’t have to guess, and neither should Sunrise support.
My home network is also my SOHO network. I need to know whether IPv6 is a supported, reliable service that I can build my network around, or whether it’s effectively experimental.
Can Sunrise please provide a definitive answer:
Is IPv6 officially supported on this connection?
Why does it repeatedly disappear?
Is the problem in the gateway, or in the Sunrise network?
What is the permanent fix?
Right now, the only thing that seems consistent is the inconsistency. IPv6 comes and goes, and Sunrise’s explanation appears to do the same.
