colinwheeler Many thanks for the clean and really great graphic. I have been looking at the graphic for a long time now and I only see this solution, which is simple and without additional costs.
The kitchen:
I don’t see any devices installed there. How about plugging the modem into the cable socket there, connecting your own router and then feeding the patch bay backwards via LAN cable and then bridging the other LAN connections cables in the patch bay itself? The only disadvantage is that you then have the full load on one LAN connection, but this should not be a problem with new routers with sufficient capacity.
Otherwise I’m running out of ideas, as you have no space in the technical room where the patch bay is.
Greetings
