0-day Game: I got ~ 18-20ms ping with the internet box, but > 40 ms with connect box 2! at least double the latency Simple internet test: I got ~ 8-10ms ping with the internet box, but > 20-25 ms with connect box 2 I did the test with IPv4
pato Ok, by default you have now an IPv6 address and a CG-NAT IPv4, which can add latency. Can you check with https://www.google.ch/search?q=show+my+ip&ie=UTF-8&oe= if it shows you an IPv6 address? If yes, you can contact @Sunrise_Team with your address, customer number and birthdate and the request to change your connection to native IPv4.
pato 0-day Ah ok, yeah that is a bit special server, as this IP address is actually not unique in the internet, but shared with many data centers. Can you try www.heise.de?
0-day These are my test with www.heise.de: internet box: connection box 2: Can this be caused by HFC? because I see the only difference is the connection cable.
pato 0-day Nah, I suspect this is because of different routing. You can test this by entering: tracert www.heise.de And I guess you will receive different results.
Daniele_Sunrise 0-day Welcome to the community! Your Connect Box 2 is not switched to IPv4. If you give me an OK, I will try to make the switch. Greetings Daniele
0-day Daniele_Sunrise Thanks! it reduced just 2~5 ms but is still higher than the internet box. Can I keep using the internet box instead of connection box 2?
pato I think you can keep it, but you will have the lower data rates. Also I imagine that Sunrise will in the future merge the two separate backbone infrastructures.
Daniele_Sunrise steepstoke Welcome to the community! Please send us your customer number, address and date of birth via private message. We will be happy to check the configuration of your modem. Greetings Daniele
