Daniele_Sunrise @redshark , Welcome to the community! We have switched your modem to IPv4. Greetings Daniele
redshark Hello would it be possible to switch ym router to IPv4 I would like to enable port forwaring best regards Susana
Daniele_Sunrise @markusKlodowsk , Welcome to the community! Please contact your provider in Poland (upc.pl) for the conversion. Greetings Daniele
markusKlodowsk Hello would it be possible to switch ym router to IPv4 I would like to enable port forwaring Thanks Markus
Daniele_Sunrise @pasco , Welcome to the community! Please contact your provider Unitymedia / Vodafone for the switch. Greetings Daniele
pasco Hi Daniel, same here. I’d like to forward a port and can’t. Would you be so kind as to change my settings as well? And what information would you need from me to do that? Regards, pasco
Daniele_Sunrise @Pymy , Welcome to the community! We have changed your modem to IPv4. Greetings Daniele
Pymy Hi @Daniele_Sunrise, I would also need a IPv4 address to enable the port forwarding. If you need anyfuther information, I’ll be happy to provide them! Thanks in advance, Bertrand
Daniele_Sunrise @Reveller , Welcome to the community! Please send us your customer number via private message so we can make the changes. Greetings Daniele
Reveller The same request for me please. I wish to also use port forwarding but currently do not have this option in my Advanced > Security settings. Can you make it so?
piotrski Resetting modem to factory details solved the issue, now I can see correct menu. Thank you Have a nice day Piotr
Daniele_Sunrise @piotrski , Please restart your modem once. If you still do not have the menu, please reset it to factory defaults. Greetings Daniele
piotrski Hi Daniele Thank you so much. Is some follow up process still ongoing? I still do not have an Internet and in modem settings, adv settings, IP and port filtering I can see “IPv6 port filtering” Thanks Best regard Piotr
Daniele_Sunrise @piotrski & @colbeny , Welcome to the community! @piotrski , we have changed your modem to IPv4. @colbeny Please contact your provider in Austria for the conversion. Greetings Daniele
colbeny Dear UPC Team, I also don’t have the port forwarding option in the menu. Could you help me with this issue? Thank you in advance. Best regards, Bence
piotrski Hello May I ask to switch my modem to IPv4 as well? I need it to enable port forwarding. Many thanks Piotr
Daniele_Sunrise @phroos , Welcome to the community! We have just changed your modem. In about 30 minutes the function will be activated. Greetings Daniele
phroos Hi, I would also like to use port forwarding. Could you please switch my connect box to IPv4? Thank you and best, Philipp
Daniele_Sunrise @Afrodite_mar , Welcome to the community! Please contact your provider in Poland (upc.pl) for the switchover. Greetings Daniele
Daniele_Sunrise @marcoz71 ,Welcome to the community! Can you please send us your customer number and complete address via private message so we can make the change? Greetings Daniele
