Archie Hello, I would also like to switch my Connectbox to IPv4 to use the port forwarding function. Thank you in advance for your help. Best regards
Ahmet_sunrise Hi @gian_c Welcome in our community. I’ve just set up your settings to IPv4. Should be active within the next hour. Best regards, Ahmet
gian_c Hello, would it be possible to switch to IPv4 on my Connectbox? I would like to be able to use the port forwarding feature for my connected devices. Best regards
Daniele_Sunrise @quentin , Welcome to the community! We have made the change as requested. In about 30 minutes the change will be completed. Greetings Daniele
Daniele_Sunrise @TC , Welcome to the community! We have made the change as requested. In about 30 minutes the change will be completed. Greetings Daniele
quentin @Daniele_Sunrise @Sunrise_Team Bonjour, pourriez-vous passer ma box en IPv4 pour que je puisse faire du port forwarding ? Merci
TC0 @Daniele_Sunrise Could you please switch my connect box to ipv4 so I can do port forwarding? Thanks
Daniele_Sunrise @panico , Herzlich Willkommen in der Community! Wir haben dein Modem wunschgemäss umgestellt. Liebe Grüsse Daniele
Ahmet_sunrise Hi @solvethiscase Welcome in our community. Thank you for your question. Please send a DM to @Sunrise_Team with your customer number. Will take care of it. Best regards, Ahmet
solvethiscase Dear @Daniele_Sunrise, would it be possible to switch my router to IPv4 as well? Cheers, Tim.
Daniele_Sunrise @ycfilip , Welcome to the community! Please contact your provider in Romania for switching (upc.ro). Greetings Daniele
Daniele_Sunrise @Caterpy , Welcome to the community! Please contact your provider in Poland (upc.pl) for a conversion. Greetings Daniele
Caterpy Sorry to bother you, but i also need to forward a few ports but don’t have the feature on my connect box. Could you switch mine too?
Daniele_Sunrise @sergeyt22 , After the conversion you can set your modem to bridge mode in the menu. After the conversion you can set your modem to bridge mode in the menu. If you do not have the menu, restart your modem. Greetings Daniele
sergeyt22 Daniele, thank you very much! Is there any chance to switch CPE into the bridge mode? I already have firewall/nat in my home network. Best regards, Sergey
Daniele_Sunrise @sergeyt22 , Welcome to the community! We have converted your modem to IPv4. In about 30 minutes the conversion will be finished. Greetings Daniele
sergeyt22 Hi! Please, switch my router to v4. I need to configure it for inbound IPv4 traffic. Thank you in advance!
