Daniele_Sunrise @EAZ & @bjornls , Welcome to the community! We have made the changeover, which will be completed in 30 minutes. Greetings Daniele
EAZ Hello, I would also like to set up a public port for my NAS. I was trying to enter the Settings but Settings password not working. Can you help? Does my modem also need to be switched to IPv4? Thank you
bjornls Hi @Daniele_Sunrise Is it possible to switch me to IPv4? I would like to do some port forwarding. Thank you in advance!
Daniele_Sunrise @NiDaHa , Welcome to the community! We have made the changeover, which will be completed in 30 minutes. Greetings Daniele
Daniele_Sunrise @tello83 ,Please restart your modem once. If this is not the solution, perform a reset. Press the reset button on the back of the modem with a pointed object for at least 25 seconds. Try it again afterwards. Greetings Daniele
tello83 Ho Daniele, Now I have problem to connect with the WIFI, maybe because I have customize the WiFi configuration? I tryed to access at router admin page with lan but after login It don’t load the page. Thanks Mauro
Daniele_Sunrise @tello83 , Welcome to the Community! We have made the changeover, which will be completed in 30 minutes. Greetings Daniele
Christoph21x Did it through UPC Switzerland Support - no further action needed. But thanks to all for this important thread. Stay healthy everybody - Chris
Christoph21x Dear hard working Daniele & Team Please switch me also to IP v4 so that I can implement port forwarding from external. Thank you very much in advance & kind greetz from Switzerland Chris
Daniele_Sunrise @scholi , Welcome to the community! We have made the changeover, which will be completed in 30 minutes. Greetings Daniele
Daniele_Sunrise @steve1138 , Welcome to the community! The switch to IPv4 has already been made. Greetings Daniele
Daniele_Sunrise @cefiro , Welcome to the community! Please send us your customer number via private message so we can make the changeover. Greetings Daniele
Daniele_Sunrise @benih & @Archie & @qualityland Welcome to the community! @benih & @Archie , We have changed your modem according to your wishes. @qualityland , please contact your provider Vodafone in Germany for the conversion Greetings Daniele
benih Hey UPC_Team, I have the same problem, can you switch my Modem to IPv4 to use port forwarding? Thank you very much!
qualityland Hey UPC_Team, I have the same problem, can you switch my Modem to IPv4 to use port forwarding? Thank you very much!
