manolis8888 Hi Daniele can you do the same for me please?My NAS, WD tv won’t work properly and i need some port forwarding too. Thanks in advance Emmanouil
egielle Hi Daniele, I’ve just tried again and now PF works like a charm. Don’t know what’s happened. I’m closing this thread, thanks for your support. Enrico
Daniele_Sunrise @egielle , how many port forwardings have you already set for the same IP? Have you ever tried to delete a port forwarding? Can you then make a new entry? Greetings Daniele
Ahmet_sunrise Hello. Thank you very much for your request. IPv4 is currently active on your modem. So port forwarding is also possible. Bes regards, @Ahmet_sunrise Member of @Sunrise_Team
egielle Hi Daniele, just restarted my Connect Box but nothing changed. I’ve also tried to reset it to factory default but nothing. I’ve attached a screenshot. What do you think? BR, Enrico
Daniele_Sunrise @egielle , please test it this afternoon and post a screenshot if it doesn’t work. Please don’t forget to restart your modem first. Greetings Daniele
egielle Hi Daniele, I’ll give it a shoot this evening but I’ve kind of doubt. I’ve checked it out yersterday at noon and port forwarding was still grayed out. I’ll keep you informed. Bye
Daniele_Sunrise @egielle ,as I see in the system, your modem has already been switched to IPv4. Can you confirm this? You may need to restart your modem. Greetings Daniele
Ahmet_sunrise Hi. Thank you for your message. Please send us your customer number as a Private message to @Sunrise_Team. We will handle this for you. Best regards, @Ahmet_sunrise Member of @Sunrise_Team
Samuel63 Hello, can someone help me please? So i need to change my ip to ipv4 so i can port forward since you can’t on ipv6, i want to port forward so i can host a server. If theres any way i can do it myself i’ll do it so i don’t bother you guys thanks!
Daniele_Sunrise Samuel63 Welcome to the UPC Community! Please contact your provider UPC Slovakia for the changeover. Unfortunately we can not do it for you from Switzerland. Greetings Daniele
Tubooo Daniele_Sunrise Hallo Daniele, Ich habe von Sunrise ein OPPO 5G CPE T1a und habe dort versucht die Portweiterleitung zu aktivieren damit ich übers Internet eine Verbindung zu meinem NAS herstellen kann. Ich habe den Hersteller des Routers bereits um eine Anleitung gebeten. Die Ports sind leider dennoch sämtlich geschlossen. Ich kann leider nicht nachvollziehen, ob das Modem über IPV4 oder 6 nach aussen kommuniziert. Könntet Ihr mir da weiterhelfen? Danke und Gruss Martin
