pulsar55 Sunrise_Team Hello, Could you please also switch my Connect Box 3 to IPv4, I need the ability to forward ports. Customer number: 8110287084 Many thanks for your efforts
Daniele_Sunrise pulsar55 Welcome to the community! We have made the switch to IPv4, which will be completed in a few minutes. Greetings Daniele
ItsRenas Hello, Could you please also switch my Connect Box 3 to IPv4? Customer number: 8108537304 Thanks a bunch.
Daniele_Sunrise ItsRenas Welcome to the community! We have made the switch to IPv4, which will be completed in a few minutes. Greetings Daniele
rryawn_1 Hi @Daniele_Sunrise and @Sunrise_Team . Please switch Connect Box to IPv4/bridge mode capable for Cust: 8108487646 Many thanks. rryawn_1
Ovazz Hi @Daniele_Sunrise and @Sunrise_Team . Could you please also switch my Connect Box 3 to IPv4? My customer ID is 8110231600. Many thanks in advance
Daniele_Sunrise Ovazz Welcome to the community! We have made the switch to IPv4, which will be completed in a few minutes. Greteings Daniele
mohammed could you please switch Connect Box 3 my connection from IPv6 to IPv4? I’d like to use my own router via the bridge mode, which apparently is only available using IPv4. My customer number is :7114004747
mohammed Hello, please, can you restart the IPv6, because the problem unfortunately still exists, thank you. My customer number is :7114004747
mohammed Merci, j’ai besoin de rétablir la fonctionnalité IPv4. Avec IPv6, tout est comme avant. Merci. My customer number is :7114004747
mohammed It seems you haven’t understood me correctly. I need to enable IPv6 and work on the company’s router, not an external device. When I tested IPv6, it didn’t work. It’s disabled, and I need it working. https://test-ipv6.com/ My customer number is :7114004747 Thank you, have a good day
Daniele_Sunrise mohammed Unfortunately, I can’t set anything else. If you access the DHCP section of the modem, you will see that you have activated both (internally). externally you have an IPv6 IP address. Greetings Daniele
