Hi everyone,
I have now received the Fiber at home and changed with the new modem. I noticed unfortuneatly that even with a newer Wifi i still miss some spot due to the fact that my router is inside the distribution closet (OTO plugin in the closet…)
So i did a scan of my home to check the coverage.
My issue is on the living room (red part) where i lose wifi connection often. I have tried a repeter for netgear but the quality is not good. It disconnect or it reduce the speed of the wifi quite significant. The version with a repater has a better coverage but a lot less stability.
I turned my Netgear as access point at the moment with a separate SSID, but I would like to have everything under 1 SSID that can handle 4800mb. if i place it into the middle of my appartment.
What would be your recommendation ? Basically my wifi is almost useless since it's inside the metal closet and a repeater bring too much unstability to the wifi that break my streaming.
