Sunrise appears to be operating its networks as cgn-NAT (carrier-grade NAT).
When I check the IP address on the router, I get an address in the range 100.97.240.xx, when I check via curl ipinfo.io/ip, I get an address of 62.167.165.xx
I would like to deactivate NAT so that my home connection is directly accessible and I can also register my public IP with DynDNS.
I saw this post did the same: https://community.sunrise.ch/d/42362-nat-deaktivieren
Thanks.
