Hi everyone,
I know this question was asked many times on this forum, and I read success and fail stories, but key data is still missing.
Recently I moved to a location where only DSL internet is available. In my previous apartment I had cable internet with UPC / Sunrise Connect box in bridge mode to which I connected my ASUS ZenWiFi AC router and mesh network and world was a happy place. I could set up VPN, DDNS and all other much needed things.
In my new apartment I received the DSL modem with Connect Box 3 DSL. Obviously, this connection is working, but as my router is assigned private IP from Connect Box 3, all my infrastructure is inaccessible from the outside.
I was able to deduct the following facts from different threads here:
- DSL version of Connect Box 3 can't work in bridge mode
- Sunrise support on the forum claims that DSL box should work with any router
- IP address is automatically assigned from DSL box via DHCP
- Public IP address is IPv4 (as seen on my Connect Box 3)
I tried connecting my Asus router (which is in Automatic IP WAN Connection Type) to DSL box, but it doesn't get IP. Here I found that DSL box does not support IPv4, only IPv6, which is odd because Connect Box 3 gets public IPv4 address.
I even tried setting up my Asus router from scratch as recommended by Sunrise support here on forum (it is in Wireless router mode / AiMesh Router mode).
And finally, yes I already called technical support without any success.
My questions are:
- Are there any additional DHCP settings or any other requirements for a router WAN connection towards DSL box
- Do I need to enable IPv6 on WAN connection
- Does anyone have exact parameters, and not only that it started working by itself
- Do DSL box or router need to be power cycled / rebooted in any particular order
- Or does anyone have any tricks in their sleeves to make this work
Thanks and best regards.
