Hi all!!
I’ve been facing an internet connectivity problem for ages and still havent found the way to fix it!
Here’s the situation :
I cant connect to the internet from home without an ethernet cable. Everytime that i try to connect with a wi fi connection the connection is either active for a couple of minutes or it’s waaaay to slow (skype won’t connect and pages take too much time to load).
However, internet connection from my laptop works perfectly while connected on other wireless connections such as libraries, cafeterias.
Is it a problem of the modem card of my laptop or it comes from the UPC modem? other laptops, mobile devices connect to the wifi of my place without any problem!
Thank you in advance for your advice
