To enable port forwarding and DMZ, switching to IPv4 is indeed necessary since many routers don’t fully support these features with IPv6. You should contact Sunrise customer support and request an IPv4 configuration or a Dual Stack setup. They should be able to make the change for you. Best of luck! With deadlines piling up, I decided to try https://domypaper.com/ DomyPaper for one of my assignments. The result was amazing! The paper was written to perfection, covering all the points required by my professor. It was a huge relief to have such professional support when I needed it the most. This service is reliable, affordable, and truly worth every penny.
