gweny1009 Hi! I’d like to ask if the newly released Google Pixel Watch 3 LTE will be supported on the Sunrise network in the future? So far it only seems to work on Swisscom. Thanks!
gweny1009 So I managed to get it to work via a simple exploit (can’t believe it worked!) Since Swisscom is now officially supported in Switzerland, get a plain prepaid eSIM from Swisscom and register it on your phone. Set Swisscom eSIM as your main network Go to the watch app -> mobile network and there you should see “Connect to Swisscom” option. Press -> scan QR Code Leave the setup camera open and then switch to your main eSIM (Galaxus Mobile, Sunrise…) and scan a Multi eSIM QR Code (mine was 5.- on Galaxus Mobile). And there you go!! LTE on the watch is working fully with my main number I deactivated the Swisscom eSIM after that.
AllenRich gweny1009 I’m a bit unclear about point 4. Once I switch back to my primary eSIM (Sunrise, in my case), what exactly do I need to do? Could you clarify what you mean by “scan a Multi eSIM QR Code”? Thanks for your help!
gweny1009 You need to scan a MultiSIM from your provider which is usually 5.- It is a eSIM that you would additionally use for a 2nd phone, but you use it for your watch instead
