maxell182
Hey Maxell
I think you may have confused this post with another one I made. What I am actually trying to show with the picture is that when I try to connect my laptop (or the pfsense) to the connect box, it does not work.
For clarification: The cables are not all connected at the same time, it is just a representation:
pfsense –> laptop = works
pfsense –> Connect Box = does not work
Laptop –> Connect Box = does not work
(where each connection is with an ethernet cable - with wifi everything works fine).
(but to answer your question:
1. No, the Connect Box is not in bridge mode.
2. No, DHCP and DNS are not disabled (can I do that? 🤔)
3. I would understand this conclusion if all the cables were connected at the same time. )
Thanks for your reply!
