I currently have copper with Sunrise, using a Connect Box 3, and I set the box in Bridge mode, and use my Ubiquiti Cloud Gateway Ultra as router.
All is fine as my current connection is 1gbit, but in september I will get fiber (2.5gbit) and i would like to fully utilize it.
First of all, I will upgrade from the Cloud Gateway Ultra to the Max, as the latter supports both 2.5gbit WAN and has 2.5gbit LAN ports,
my question is, from what I’m reading, the new fiber router that Sunrise will send me once I get fiber, won’t allow to be set in Bridge mode, is this correct?
Is the only way now to set it up with DMZ, and then use my Gateway Max as router?
Are there any solutions to allow us, with a fiber connection, to not use the Sunrise router? if so, any hardware from Ubiquiti to achieve this?
