Hi,
I have this Zyxel AX7501-B for a while now.
Recently I was informed by Sunrise there was a line upgrade occuring on my location. On the FAQ it said I needed a new modem:
I’d prefer to keep my old modem, is it possible?
No, unfortunately not.
When you receive a new modem from us, you really must replace your old modem as it won’t support the new technology where you live.
Therefore my question is the new model should be the connect box 3? Maybe there will be a release of a newer device soon like hypothetically connect box 4 or anything? I dont need to know a fixed date but maybe an indication if there will be a newer device in next few months (then I would wait).
Also I havent received automatically a new model and the zyxel misbehave sometimes since the update. Should I expect the Connect Box 3 to be better and stable?
I have the 10gbps line by the way.
Thanks in advance.
