isambard1 We do not perform a firmware update every day at the same time. Your error picture rather reads that an IP release takes place at the same time, which corresponds to approx. 84600 seconds and is the default setting.
How exactly is the device that has the interruption connected to the internet? Via WIFI from your Apple AirPort? If so, I would reset your AirPort once, as it is not receiving an IP or is receiving the wrong IP.
In addition, one of your devices that is no longer online has an incorrect fixed internal IP address. This could also be causing interference.
Greetings
