pbp Hello there. I’m trying to do some port forwarding, but I noticed that I can’t use IPv4 addresses for the ports. How can I edit settings using devices’ IPv4 address? Thank you.
Daniele_Sunrise pbp Welcome to the community! Please send us your customer number, address and date of birth via private message for processing. We will then be happy to check the configuration of your modem. Greetings Daniele
Daniele_Sunrise pbp We have made the switch to IPv4, which will be completed in a few minutes. Greetings Daniele
maxell182 CaseyFlynn I think you’re in the wrong post. This one got solved 8days ago, otherwise pbp would’ve written. br maxell182
