GuillermoPloNeira i need to use nordVPN and ive seen that its necesary to disable this function, how can i do it?
Daniele_Sunrise GuillermoPloNeira Welcome to the community! We have activated IPv4 as a test, which will be completed in a few minutes. Can you please test it again afterwards? Greetings Daniele
GuillermoPloNeira ive managed to disable it from web and now its working but i dont understand why is so slow with the vpn, maybe needed to change ipv4?
GuillermoPloNeira Daniele_Sunrise Hello, the VPN stopped working again, can you please check if the configuration is still correct?
