djaafar2 I need help, have 2 old Nokia phones locked to Sunrise Nokia 100 and Nokia 1616 1616 imie 354826040266678 Nokia 100 imie 356707055876254 I will appreciate it if someone can provide me network unlock code thanks in advance
Daniele_Sunrise djaafar2 Enclosed we will send you the unlock codes. Can you please let us know if everything worked? For IMEI 354826040266678 the unlock code is: 932577151297853 For IMEI 356707055876254 the unlock code is: 80566171166476028194 Greetings Daniele
Sunrise_Team Thank you very much for your message. We’re happy to send you the codes. We would ask you to send us your customer number per private message so that we can have an insight. Once you send us these, we’ll be able to find out the codes. Best regards Helena
djaafar2 Honestly, I don’t have customer number, and I am outside Switzerland now and need this code to unlock those two old Nokia phones to give it to an old man because he can use simple phone only
djaafar2 Many thanks 1st code worked ok 2nd 20 digits did not worked with +1 also with +7 anyway thank you very much one saved now working very good
