morges Hi! I have a UPC Giga Connect Box device. I’d have a few questions: I’d like to be able to configure IPv4 port-forwarding rules, so a certain arbitrary port on my public IP would be forwarding to a certain local IPv4 IP, is it possible to enable this kind of functionality for me in the admin panel? I want to use it to set-up a private VPN server for a few client devices I have (phone, laptop). As I was reading through other threads, as I understand it’s impossible to let me configure a custom DNS server IP on the router level, isn’t it? As I understand the only solution is to bridge it to a privately owned router with more privileges? If it’s still the case, I think it’s ok for me to do it on the client level by hand. Not yet purchasing an own router. I have a VM with a DNS server I’d love to route all traffic through by default. Thanks!
Daniele_Sunrise morges Welcome to the community! We have made the switch to IPv4, which will be completed in a few minutes. Regarding your second question, it is correct that you cannot customize the DNS servers on the modem. Greetings Daniele
