adrianlondon
thank you for the very quick answers.
One important question: does this box that you mentioned, allow “channel up / channel down” signals via infrared as well?
(since the channel switching buttons are the only ones that do not work with IR for the model that I have - they seem to be bluetooth only on my box).
So could you check the channel switching buttons to be IR as well ?
Remains the question if I can use your box also for a house that has fibre already?
Thank you for your support
P.S. My Box looks exactly like your link shows, except that it has two more buttons (plus/minus) to the left of the UPC logo. So mine is also older and still UPC-branded as well.
