The Up Mobile L 40 GB roaming limit at high speed in Europe is per month? In the specifications it says
“Mobile Internet in Europe Unlimited data volume, of which 40 GB at maximum possible high speed. Once this amount has been used up, it is possible to continue enjoying unlimited surfing, but at a reduced speed (downloads 256 kbit/s, uploads 128 kbit/s).”
but it is not clear if this 40 GB limit is per year or per month and if it is a total on all countries or a separate limit in each single country (so for instance if I consume 20 GB in Austria and 20 GB in Italy will the limit be reached or not? )
Thank you in advance for help
Best Regards
