Hello.
I need some advice about this (Connecting a second - older - TV).
As the TV doesn’t support the UPC TV app, I am guessing I need a second TV box?
So, I just have some general high-level questions like:
Is that correct?
What is the cost of the second TV box?
Does the box run off the WiFi, or do I need to connect it “hard” via cable / wire?
(I have the sockets in the wall next to this older TV, but I am not sure they are “live”… do I need another router too?)
Any help / advice would be great,
Thanks, Jonathan.
