BarryMc Hi, My Giga Box is flashing red and I have no internet, I’m currently working from home which is now impossible without internet. What should I do??? I have tried turning box off for approx 10 minutes but fault returns after I switch it back on
Daniele_Sunrise BarryMc We are currently experiencing an outage in your region. If you log into MyUPC, you should see the outage message. Greetings Daniele
BarryMc Hi Daniel, can’t log onto SUNRISE, won’t accept login attempt, rang The technical desk and they said they also cannot login to check if there are issues ???
Daniele_Sunrise BarryMc You need to log into MyUPC, not Sunrise. Here is the link: https://www.upc.ch/en/account/login/credentials/ Greetings Daniele
BarryMc Internet back and website working, spoke to Tech Services and they said there’s a problem in the area and it might go down again, they have people working on it
