localhost7 Hi, I have a VPN server at home. I have a new contract starting today and I also changed the connection speed. Since then, I lost my access to my VPN at home. Can you please check? Am I on IPv6 or IPv4? Thanks
maxell182 localhost7 IPv4/v6 Check ist here: Wie ist meine IP-Adresse? If you are on v6 use this guide to switch to v4: Switch modem from IPv6 DS lite to IPv4 - Sunrise Community br maxell182
Daniele_Sunrise localhost7 Your connection is on IPv4. Since you have your own router in use with the bridged modem, I recommend you to check on your router if you have external public IPs stored somewhere. These may have changed and may need to be set to the new public IP address. Greetings Daniele
