DiogoM Dear Sunrise, I’ve ordered Connect Wifi and there it says: SIM Card (incl activation) Online advantage 0,- instead of 29,- And then in my next bill: DELETED - Sunrise SIM 3-1 deac. fix PIN - DELETED Total cost 29.– Did I miss something? Thanks, Diogo
Sunrise_Team DiogoM Thank you for your message. Please check page 4 of 6; theres a discount of 29.-, made to adjust the invoice and remove the Sim Card Cost: Best Regards, Luka
DiogoM Thank you Luka. Indeed it’s correct in the exported PDF, I only look at the website details where I don’t see the discount. Thank you!
