Eskay Hi , How to turn-off IPv6 and switch to IPv4 only. I tried to switch off but it’s turn on itself. is it possible to make it modem only. I have my own router and firewall running.
Daniele_Sunrise Eskay We have just changed your modem to IPv4. Can you please try again? Greetings Daniele
Eskay Daniele_Sunrise Thanks Daniele. I can see IPv6 is switched off now. Do you see any option to turn off router part in the box . It will help me get out of double NAT.
Daniele_Sunrise Eskay As far as I know, you can only bridge cable modems. With your modem you can use the DMZ mode, which allows you to use your router. Greetings Daniele
