I’ve just installed an Asus Router behind my UPC Gigabox (which is now in Bridge Mode] and am unsure where to connect the Ethernet connection from my TV Box. There are two options, either my router or the Gigabox. I’d like to have the TV Box connected to my router so that I can monitor/configure network control via Asus tools available in the router. I have tried this but Iptv loses its connection everytime I make configuration changes on my router; this obviously doesn’t happen if the TV Box is connected directly to the Gigabox, which sits in front of my router.
I see the router (Asus Zenwifi XT-12) incudes options for configuring an iptv connection. Does anyone know what settings/connections should be used to enable a stable iptv connection when using an Asus router?
