kajeczka2 Hi, since couple of days, the wifi gets disconnected on my tv. It is the only device which keeps on being disconnected. Could you please advise what should I do?
Daniele_Sunrise kajeczka2 Is it a Samsung TV? This is shown to us as a device not connected via LAN. Does your TV use this WIFI: k***2? If not, can you please connect the TV to this WIFI? Also, I would check if your TV has the latest firmware update. Greetings Daniele
kajeczka2 I struggle again with the same issue. While connected to k***2, wifi on tv disconnets all the time. I need to connect to network couple of times on tv to make this work. I’ve restarted the device many times already.
Daniele_Sunrise kajeczka2 If you want, I can send you a Connect Pod for free, which will extend your WIFI signal. Greetings Daniele
