Hi,
I have 1Gbps (download)/100 Mbps (upload) package. Via Wi-Fi I can achieve max ~500Mbps while my LAN connection is capped at 100Mbps.
I am using Sunrise provided cable CAT 5e (allows 1Gbps speeds) without any switched in between my computer and router.
The 100Mbps speed is displayed on Sunrise > Connected devices > Speed column. From speedtest I get: 85 Mbps/75 Mbps on LAN connection.
Is connection capped at the router level? I would like to use full speed on my ethernet as well.
Thank you!
