Hello everyone, good morning.
I actually have a Connect Box, but I have two problems which until now I don't find a solution to, so I try here if possible:
1- I need to disable UPnP but the option doesn't appear in de Advanced settings;
2- I need to configure Port Forwarding but the option doesn't appear in the Security.
Just for curiosity I already tried making a Factory restore, rebooting a lot of times, turning off and turning on the Firewall.
Another point, I disable the WiFi of the Connect box and I use one Router NETGEAR to improve the signal.
If someone knows how I can habilitate these two options, please let me know I would be very grateful.
Thanks for your attention and help.
With best regards,
Jeison Terci
