AlexandruB You do not need a UPC TV box, as long as the normal channel offer in the Basic package is sufficient for you. You can plug your TV directly into your cable connection socket.
![](https://community.sunrise.ch/assets/files/2021-11-23/1637668864-690236-image.png)
Then you search via this link for the setup ID and enter this data before the search in the appropriate fields in the TV menu when you are asked.
Greetings
