Hi Daniele,
I wanted to provide an update on the situation as its been a week since the switch to IPv4.
The stability of the connection seems to be much better than it was on IPv6 but we still get a dropouts and/or very slow speeds maybe once every 2 days or so. This is much better than it was though so we are happy to stay on IPv4 for now.
One thing I’ve noticed is that we have a 2 hole socket that we connect the modem to in the wall but the cable is very very loose. I’ve noticed that our speeds are worse when the cable isn’t fully pushed into the wall socket and given there is very little resistance in the socket any slight movement in the cable tends to pull the cable out of the wall slightly or completely. The female coaxial connection inside the wall socket doesn’t look like its in the best condition so maybe that’s why.
Is there any way to make sure the cable stays in the wall better or do we need a new wall socket? We only have 1 in our apartment and it was installed before we moved in so I don’t know how old it is.
Many thanks,
Chris
