Hi,hier die screenshots aus dem Connect Box Interface
Netzwerk Log
| Zeit | Priorität | Beschreibung |
12-10-2017 16:02:28 | critical | No Ranging Response received - T3 time-out;CM-MAC=90:5c:44:43:3e:5e;CMTS-MAC=00:17:10:87:30:0e;CM-QOS=1.1;CM-VER=3.0; |
17-09-2017 09:52:18 | critical | No Ranging Response received - T3 time-out;CM-MAC=90:5c:44:43:3e:5e;CMTS-MAC=00:17:10:87:30:0e;CM-QOS=1.1;CM-VER=3.0; |
11-09-2017 10:53:37 | critical | No Ranging Response received - T3 time-out;CM-MAC=90:5c:44:43:3e:5e;CMTS-MAC=00:17:10:87:30:0e;CM-QOS=1.1;CM-VER=3.0; |
11-09-2017 10:53:36 | notice | TLV-11 - unrecognized OID;CM-MAC=90:5c:44:43:3e:5e;CMTS-MAC=00:17:10:87:30:0e;CM-QOS=1.1;CM-VER=3.0; |
11-09-2017 10:53:31 | warning | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=90:5c:44:43:3e:5e;CMTS-MAC=00:17:10:87:30:0e;CM-QOS=1.1;CM-VER=3.0; |
11-09-2017 10:52:49 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=90:5c:44:43:3e:5e;CMTS-MAC=00:17:10:87:30:0e;CM-QOS=1.1;CM-VER=3.0; |
11-09-2017 10:52:27 | warning | Lost MDD Timeout;CM-MAC=90:5c:44:43:3e:5e;CMTS-MAC=00:17:10:87:30:0e;CM-QOS=1.1;CM-VER=3.0; |
11-09-2017 10:52:21 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=90:5c:44:43:3e:5e;CMTS-MAC=00:17:10:87:30:0e;CM-QOS=1.1;CM-VER=3.0; |
11-09-2017 10:51:18 | notice | TLV-11 - unrecognized OID;CM-MAC=90:5c:44:43:3e:5e;CMTS-MAC=00:17:10:87:30:0e;CM-QOS=1.1;CM-VER=3.0; |
11-09-2017 10:51:13 | warning | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=90:5c:44:43:3e:5e;CMTS-MAC=00:17:10:87:30:0e;CM-QOS=1.1;CM-VER=3.0; |
Allgemeine Konfiguration
Netzwerkzugang | Erlaubt |
Maximale Anzahl der Endgeräte | 4 |
Basis Datenschutz | Aktiviert |
DOCSIS Modus | DOCSIS 3.0 |
Konfigurationsdatei | lemon_v4-sip.bin |
Primary Downstream Service Flow
SFID | 77439168 |
Maximale Datenverkehrsrate | 11000000 bps |
Maximaler Traffic Burst | 42600 bytes |
Minimale Datenverkehrsrate | 0 bps |
SFID | 77439167 |
Maximale Datenverkehrsrate | 128000 bps |
Maximaler Traffic Burst | 3044 bytes |
Minimale Datenverkehrsrate | 12000 bps |
SFID | 77439166 |
Maximale Datenverkehrsrate | 410000000 bps |
Primary Upstream Service Flow
SFID | 77430978 |
Maximale Datenverkehrsrate | 550000 bps |
Maximaler Concatenated Burst | 42600 bytes |
Art der Zeitplanung | Best Effort |
SFID | 77430977 |
Maximaler Concatenated Burst | 1522 bytes |
SFID | 77430973 |
Maximale Datenverkehrsrate | 42000000 bps |
Upstream verbundene Kanäle
Kanal | Frequenz (Hz) | Signalstärke (dBmV) | Symbol Rate (ksps) | Modulation | Kanal ID |
1 | 51100000 | 41 | 5.120 | 64qam | 2 |
2 | 57900000 | 42 | 5.120 | 64qam | 1 |
3 | 44200000 | 42 | 5.120 | 16qam | 3 |
4 | 30700000 | 45 | 5.120 | 16qam | 4 |
Kanal | Kanal Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
1 | 2.0 | 0 | 0 | 68 | 0 |
2 | 2.0 | 0 | 0 | 59 | 0 |
3 | 2.0 | 0 | 0 | 66 | 0 |
4 | 2.0 | 0 | 0 | 71 | 0 |
Downstream verbundene Kanäle
Kanal | Frequenz (Hz) | Signalstärke (dBmV) | SNR (dB) | Modulation | Kanal ID |
1 | 594000000 | 11 | 37 | 256qam | 1 |
2 | 602000000 | 12 | 37 | 256qam | 2 |
3 | 610000000 | 11 | 37 | 256qam | 3 |
4 | 618000000 | 11 | 38 | 256qam | 4 |
5 | 626000000 | 10 | 37 | 256qam | 5 |
6 | 634000000 | 10 | 37 | 256qam | 6 |
7 | 642000000 | 10 | 37 | 256qam | 7 |
8 | 650000000 | 9 | 37 | 256qam | 8 |
9 | 658000000 | 10 | 37 | 256qam | 9 |
10 | 666000000 | 8 | 37 | 256qam | 10 |
11 | 674000000 | 9 | 37 | 256qam | 11 |
12 | 682000000 | 9 | 37 | 256qam | 12 |
13 | 690000000 | 8 | 36 | 256qam | 13 |
14 | 698000000 | 8 | 36 | 256qam | 14 |
15 | 706000000 | 6 | 36 | 256qam | 15 |
16 | 714000000 | 6 | 36 | 256qam | 16 |
Kanal | Locked Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
1 | Locked | 37.636 | 92770100470 | 708 |
2 | Locked | 37.636 | 92769165368 | 530 |
3 | Locked | 37.636 | 92769165914 | 531 |
4 | Locked | 38.605 | 92769166585 | 520 |
5 | Locked | 37.636 | 92769163228 | 1294 |
6 | Locked | 37.356 | 92769166696 | 1080 |
7 | Locked | 37.636 | 92769166960 | 719 |
8 | Locked | 37.636 | 92769166523 | 1341 |
9 | Locked | 37.356 | 92769163019 | 1324 |
10 | Locked | 37.356 | 92769166463 | 1939 |
11 | Locked | 37.636 | 92769165249 | 2757 |
12 | Locked | 37.356 | 92769163068 | 3661 |
13 | Locked | 36.387 | 92769153686 | 13756 |
14 | Locked | 36.387 | 92769140239 | 21886 |
15 | Locked | 36.610 | 92769147705 | 19123 |
16 | Locked | 36.387 | 92769120305 | 45594 |
Connect Box Status
Element | Status | Anmerkungen |
Zugewiesener Downstream Kanal(Hz) | 594000000 | Locked |
Ranged Upstream Channel(Hz) | 51100000 | Ranged |
Provisionierungsstatus | Online | In Betrieb |
