Hi,
I’ve not changed my settings, and am always using the same “shared” profile. Over the last few days, BBC1 HD is no longer defaulting to “English” when the box is turned on but to “original”. This is the language with audio descriptions for the hard of seeing.
You’ve started watching something and “the man walks over to the other side of the room and sits down” gets said 🙂
A quick check of other channels and only BBC1 HD seems affected.
Can someone at UPC check if this can be changed back? Or is it an issue just with my box? I’ve already tried unplugging, but I could do a factory reset if necessary.
