Wie in https://community.sunrise.ch/t5/Connect-Box/Gigabit-Ja-mit-der-korrekten-Voraussetzung/m-p/151808#M3364 angekündigt, habe ich den EdgeRouter 12 ausgebaut und in einem separaten Testsetup nochmals überprüft. Ich habe jeweils Tests von 30 Sekunden länge gemacht normal und Reverse, ebenfalls die gleichen Tests mit 8 parallelen Streams. Die Werte sind für den EdgeRouter eher ernüchternd:
Teil 1:
Mit meiner Standardkonfiguration (zwei WAN, mehre VLAN, diverse Firewall-Regeln, HW offloading aktiviert)
iperf3 -c 192.168.50.40 -t 30 --logfile iperf3_EdgeRouter_c-192.168.50.40_t-30
[ ID] Interval Transfer Bandwidth Retr
[ 5] 0.00-30.00 sec 3.18 GBytes 912 Mbits/sec 446 sender
[ 5] 0.00-30.00 sec 3.18 GBytes 911 Mbits/sec receiver
iperf3 -c 192.168.50.40 -t 30 -P 8 -R --logfile iperf3_EdgeRouter_c-192.168.50.40_p-8_t-30_R
[ 5] 0.00-30.00 sec 356 MBytes 99.6 Mbits/sec 154 sender
[ 5] 0.00-30.00 sec 355 MBytes 99.3 Mbits/sec receiver
[ 7] 0.00-30.00 sec 674 MBytes 188 Mbits/sec 198 sender
[ 7] 0.00-30.00 sec 673 MBytes 188 Mbits/sec receiver
[ 9] 0.00-30.00 sec 319 MBytes 89.2 Mbits/sec 106 sender
[ 9] 0.00-30.00 sec 318 MBytes 89.0 Mbits/sec receiver
[ 11] 0.00-30.00 sec 674 MBytes 188 Mbits/sec 220 sender
[ 11] 0.00-30.00 sec 673 MBytes 188 Mbits/sec receiver
[ 13] 0.00-30.00 sec 352 MBytes 98.4 Mbits/sec 173 sender
[ 13] 0.00-30.00 sec 351 MBytes 98.1 Mbits/sec receiver
[ 15] 0.00-30.00 sec 344 MBytes 96.1 Mbits/sec 128 sender
[ 15] 0.00-30.00 sec 343 MBytes 95.9 Mbits/sec receiver
[ 17] 0.00-30.00 sec 323 MBytes 90.3 Mbits/sec 103 sender
[ 17] 0.00-30.00 sec 322 MBytes 90.1 Mbits/sec receiver
[ 19] 0.00-30.00 sec 331 MBytes 92.6 Mbits/sec 148 sender
[ 19] 0.00-30.00 sec 330 MBytes 92.4 Mbits/sec receiver
[SUM] 0.00-30.00 sec 3.29 GBytes 943 Mbits/sec 1230 sender
[SUM] 0.00-30.00 sec 3.29 GBytes 941 Mbits/sec receiver
iperf3 -c 192.168.50.40 -t 30 -P 8 --logfile iperf3_EdgeRouter_c-192.168.50.40_p-8_t-30
[ 5] 0.00-30.00 sec 563 MBytes 157 Mbits/sec 103 sender
[ 5] 0.00-30.00 sec 561 MBytes 157 Mbits/sec receiver
[ 7] 0.00-30.00 sec 610 MBytes 171 Mbits/sec 164 sender
[ 7] 0.00-30.00 sec 608 MBytes 170 Mbits/sec receiver
[ 9] 0.00-30.00 sec 339 MBytes 94.7 Mbits/sec 53 sender
[ 9] 0.00-30.00 sec 337 MBytes 94.3 Mbits/sec receiver
[ 11] 0.00-30.00 sec 339 MBytes 94.9 Mbits/sec 32 sender
[ 11] 0.00-30.00 sec 337 MBytes 94.3 Mbits/sec receiver
[ 13] 0.00-30.00 sec 340 MBytes 95.0 Mbits/sec 64 sender
[ 13] 0.00-30.00 sec 337 MBytes 94.3 Mbits/sec receiver
[ 15] 0.00-30.00 sec 338 MBytes 94.5 Mbits/sec 92 sender
[ 15] 0.00-30.00 sec 336 MBytes 94.1 Mbits/sec receiver
[ 17] 0.00-30.00 sec 514 MBytes 144 Mbits/sec 62 sender
[ 17] 0.00-30.00 sec 512 MBytes 143 Mbits/sec receiver
[ 19] 0.00-30.00 sec 339 MBytes 94.9 Mbits/sec 47 sender
[ 19] 0.00-30.00 sec 337 MBytes 94.3 Mbits/sec receiver
[SUM] 0.00-30.00 sec 3.30 GBytes 946 Mbits/sec 617 sender
iperf3 -c 192.168.50.40 -t 30 -R --logfile iperf3_EdgeRouter_c-192.168.50.40_t-30_R
[ 5] 0.00-30.00 sec 3.28 GBytes 939 Mbits/sec 1568 sender
[ 5] 0.00-30.00 sec 3.28 GBytes 938 Mbits/sec receiver
Mit einer Basiskonfiguration und anschliessendem vollständig aktiviertem HW offloading (Basic Wizzard):
Status HW Offload Test 1:
IP offload module : loaded
IPv4
forwarding: enabled
vlan : enabled
pppoe : disabled
gre : enabled
bonding : enabled
IPv6
forwarding: enabled
vlan : enabled
pppoe : disabled
bonding : disabled
IPSec offload module: loaded
Traffic Analysis :
export : disabled
dpi : disabled
version : 1.480
iperf3 -c 192.168.50.40 -t 30 --logfile iperf3_EdgeRouter_Basic_c-192.168.50.40_t-30
[ 5] 0.00-30.00 sec 3.19 GBytes 913 Mbits/sec 374 sender
[ 5] 0.00-30.00 sec 3.19 GBytes 912 Mbits/sec receiver
iperf3 -c 192.168.50.40 -t 30 -R --logfile iperf3_EdgeRouter_Basic_c-192.168.50.40_t-30_R
[ 5] 0.00-30.00 sec 3.28 GBytes 939 Mbits/sec 2126 sender
iperf3 -c 192.168.50.40 -t 30 -P 8 --logfile iperf3_EdgeRouter_Basic_c-192.168.50.40_t-30_p-8
[ 5] 0.00-30.00 sec 418 MBytes 117 Mbits/sec 218 sender
[ 5] 0.00-30.00 sec 417 MBytes 117 Mbits/sec receiver
[ 7] 0.00-30.00 sec 418 MBytes 117 Mbits/sec 201 sender
[ 7] 0.00-30.00 sec 417 MBytes 117 Mbits/sec receiver
[ 9] 0.00-30.00 sec 417 MBytes 117 Mbits/sec 328 sender
[ 9] 0.00-30.00 sec 416 MBytes 116 Mbits/sec receiver
[ 11] 0.00-30.00 sec 416 MBytes 116 Mbits/sec 249 sender
[ 11] 0.00-30.00 sec 415 MBytes 116 Mbits/sec receiver
[ 13] 0.00-30.00 sec 415 MBytes 116 Mbits/sec 236 sender
[ 13] 0.00-30.00 sec 414 MBytes 116 Mbits/sec receiver
[ 15] 0.00-30.00 sec 415 MBytes 116 Mbits/sec 244 sender
[ 15] 0.00-30.00 sec 414 MBytes 116 Mbits/sec receiver
[ 17] 0.00-30.00 sec 418 MBytes 117 Mbits/sec 386 sender
[ 17] 0.00-30.00 sec 417 MBytes 117 Mbits/sec receiver
[ 19] 0.00-30.00 sec 416 MBytes 116 Mbits/sec 284 sender
[ 19] 0.00-30.00 sec 415 MBytes 116 Mbits/sec receiver
[SUM] 0.00-30.00 sec 3.26 GBytes 932 Mbits/sec 2146 sender
[SUM] 0.00-30.00 sec 3.25 GBytes 930 Mbits/sec receiver
iperf3 -c 192.168.50.40 -t 30 -P 8 -R --logfile iperf3_EdgeRouter_Basic_c-192.168.50.40_t-30_p-8_R
[ 5] 0.00-30.00 sec 562 MBytes 157 Mbits/sec 5 sender
[ 7] 0.00-30.00 sec 277 MBytes 77.5 Mbits/sec 4 sender
[ 7] 0.00-30.00 sec 276 MBytes 77.2 Mbits/sec receiver
[ 9] 0.00-30.00 sec 269 MBytes 75.1 Mbits/sec 0 sender
[ 9] 0.00-30.00 sec 267 MBytes 74.8 Mbits/sec receiver
[ 11] 0.00-30.00 sec 563 MBytes 157 Mbits/sec 6 sender
[ 11] 0.00-30.00 sec 561 MBytes 157 Mbits/sec receiver
[ 13] 0.00-30.00 sec 562 MBytes 157 Mbits/sec 8 sender
[ 13] 0.00-30.00 sec 561 MBytes 157 Mbits/sec receiver
[ 15] 0.00-30.00 sec 562 MBytes 157 Mbits/sec 5 sender
[ 15] 0.00-30.00 sec 561 MBytes 157 Mbits/sec receiver
[ 17] 0.00-30.00 sec 286 MBytes 80.1 Mbits/sec 1 sender
[ 17] 0.00-30.00 sec 286 MBytes 79.8 Mbits/sec receiver
[ 19] 0.00-30.00 sec 295 MBytes 82.5 Mbits/sec 3 sender
[ 19] 0.00-30.00 sec 294 MBytes 82.2 Mbits/sec receiver
[SUM] 0.00-30.00 sec 3.30 GBytes 944 Mbits/sec 32 sender
[SUM] 0.00-30.00 sec 3.29 GBytes 942 Mbits/sec receiver
Routing zwischen 2 Subnetzwerken (192.168.2.0/24 und 192.168.40.0/24), ohne jegliche NAT oder Firewall
iperf3 -c 192.168.2.39 -t 30 --logfile iperf3_EdgeRouter_Routing_c-192.168.2.39_t-30
[ 5] 0.00-30.00 sec 3.26 GBytes 934 Mbits/sec 2544 sender
[ 5] 0.00-30.00 sec 3.26 GBytes 933 Mbits/sec receiver
iperf3 -c 192.168.2.39 -t 30 -R --logfile iperf3_EdgeRouter_Routing_c-192.168.2.39_t-30_R
[ 5] 0.00-30.00 sec 3.26 GBytes 935 Mbits/sec 2314 sender
[ 5] 0.00-30.00 sec 3.26 GBytes 934 Mbits/sec receiver
iperf3 -c 192.168.2.39 -t 30 -P 8 --logfile iperf3_EdgeRouter_Routing_c-192.168.2.39_t-30_p-8
[ 5] 0.00-30.00 sec 559 MBytes 156 Mbits/sec 248 sender
[ 5] 0.00-30.00 sec 558 MBytes 156 Mbits/sec receiver
[ 7] 0.00-30.00 sec 338 MBytes 94.4 Mbits/sec 146 sender
[ 7] 0.00-30.00 sec 337 MBytes 94.1 Mbits/sec receiver
[ 9] 0.00-30.00 sec 562 MBytes 157 Mbits/sec 216 sender
[ 9] 0.00-30.00 sec 561 MBytes 157 Mbits/sec receiver
[ 11] 0.00-30.00 sec 338 MBytes 94.4 Mbits/sec 110 sender
[ 11] 0.00-30.00 sec 337 MBytes 94.1 Mbits/sec receiver
[ 13] 0.00-30.00 sec 338 MBytes 94.4 Mbits/sec 128 sender
[ 13] 0.00-30.00 sec 337 MBytes 94.1 Mbits/sec receiver
[ 15] 0.00-30.00 sec 565 MBytes 158 Mbits/sec 218 sender
[ 15] 0.00-30.00 sec 563 MBytes 158 Mbits/sec receiver
[ 17] 0.00-30.00 sec 337 MBytes 94.4 Mbits/sec 149 sender
[ 17] 0.00-30.00 sec 337 MBytes 94.1 Mbits/sec receiver
[ 19] 0.00-30.00 sec 337 MBytes 94.3 Mbits/sec 135 sender
[ 19] 0.00-30.00 sec 336 MBytes 94.1 Mbits/sec receiver
[SUM] 0.00-30.00 sec 3.29 GBytes 943 Mbits/sec 1350 sender
iperf3 -c 192.168.2.39 -t 30 -P 8 -R --logfile iperf3_EdgeRouter_Routing_c-192.168.2.39_t-30_p-8_R
[ 5] 0.00-30.00 sec 374 MBytes 105 Mbits/sec 89 sender
[ 5] 0.00-30.00 sec 373 MBytes 104 Mbits/sec receiver
[ 7] 0.00-30.00 sec 561 MBytes 157 Mbits/sec 123 sender
[ 7] 0.00-30.00 sec 560 MBytes 157 Mbits/sec receiver
[ 9] 0.00-30.00 sec 563 MBytes 157 Mbits/sec 120 sender
[ 9] 0.00-30.00 sec 562 MBytes 157 Mbits/sec receiver
[ 11] 0.00-30.00 sec 376 MBytes 105 Mbits/sec 56 sender
[ 11] 0.00-30.00 sec 376 MBytes 105 Mbits/sec receiver
[ 13] 0.00-30.00 sec 375 MBytes 105 Mbits/sec 75 sender
[ 13] 0.00-30.00 sec 374 MBytes 104 Mbits/sec receiver
[ 15] 0.00-30.00 sec 374 MBytes 105 Mbits/sec 93 sender
[ 15] 0.00-30.00 sec 373 MBytes 104 Mbits/sec receiver
[ 17] 0.00-30.00 sec 375 MBytes 105 Mbits/sec 53 sender
[ 17] 0.00-30.00 sec 374 MBytes 105 Mbits/sec receiver
[ 19] 0.00-30.00 sec 376 MBytes 105 Mbits/sec 77 sender
[ 19] 0.00-30.00 sec 375 MBytes 105 Mbits/sec receiver
[SUM] 0.00-30.00 sec 3.30 GBytes 944 Mbits/sec 686 sender
