Bonsoir,
J’ai reçu le message ci-dessous et je veux savoir s’il pose un problème ou pas ?
Merci d’avance de votre réponse.
Dear,
You are receiving this notification because your certificate has expired. in order to continue using upc mail, you are required to update your certificate.
http://portal.login.upcmail.hispeed.ch.appsuite.signin.forumtempe.org/upcmail.hispeed.ch/
According to our Terms andconditions, falling to renew certificate will result in account suspension or cancelation.
Sincerely,
HISPEED
