Is it happening on more than one device? By that I mean are those sites blocked both when using a laptop and also a phone?
One test you can do is to turn off your modem and connect to one of the “Wi-Free” networks (assuming you didn’t disable your access to that). I find this a great way to test if it’s my infrastructure or IP address that’s causing the issue.
