Anybody have the full set of instructions to connecting Giga Connect Box in bridge mode to another Router (mine is AC5300- Asus) this properly?
For example: Where to connect all the cables to (e.g.: Wall socket "lan"cable to Connect Box or to Asus router?)?
This is the only thing I found, but looks to easy to be true and I’m sure you have to manually tweak some settings (and connect all cables correctly):
https://support-en.upc.ch/app/faq/a_id/1324/bridge-mode-with-wlan-modem
Thanks for the assistance in advance!
Luciano Neves
