Daniele_Sunrise @gdjdtjm , I have just sent you a private message. The activation of the new modem is an automatic process. We have not intervened here. Greetings Daniele
gdjdtjm Dear Daniele, I really can’t understand what you’ve broken the old link for? Could you recover it until when you will troubleshoot the new one? I’m not ready waiting for days without a connection. Should I call to your hot line?
adrianlondon One hour? They cut me off Thursday morning and I’ve had no internet, a TV box that only half works, and a completely dead landline since. Luckily, Wi-Free works.
Daniele_Sunrise @gdjdtjm , Could you please send me a photo from the bottom of your new modem via private message? The new Modem ist not active yet. Greetings Daniele
gdjdtjm The modem is online, yep but it can’t get an IPv4, here a log record: DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=e4:57:40:b1:2a:d0;CMTS-MAC=00:17:10:91:15:09;CM-QOS=1.1;CM-VER=3.1;
adrianlondon I’ve been waiting since around 11am for my new giga box to get an IP address; nothing so far. I believe it’s a public holiday in some cantons, and I wonder whether the folks who do the new modem activations for UPC are based in one of those 🙂
gdjdtjm Dear Daniele, Thank you for the reply. I switched it to the bridge mode but the router can’t obtain an address, it’s a strange because the previous one works as expected. Could you please chek it? Cheers.
Daniele_Sunrise @gdjdtjm , Welcome to the community! Your modem is already on IPv4. The new modem will adopt this setting. Greetings Daniele
gdjdtjm Dear Daniele, Could you plese switch my Giga Connect box to IPv4. My customer ID: 6214306 Thanks.
Daniele_Sunrise @xabu , Welcome to the Community! We have made the changeover, which will be completed in 30 minutes. Restart your modem afterwards. If you have problems, reset your modem. Press the reset button on the back of the modem with a pointed object for at least 25 seconds. Then try again. Greetings Daniele
xabu Hi UPC Support Team, Would it be also possible to switch my Connect Box to IPv4? Thank you very much ! Bests Xavier
Daniele_Sunrise @adibou , Welcome to the community! We have made the changeover, which will be completed in 30 minutes. Greetings Daniele
adibou Hello Daniele, Can you please switch my Giga connect box to IPv4 so I can forward the ports. Thanks and have a nice day! Best Regards Arnaud client n: 6847283-1
Daniele_Sunrise @bergfrieden , Please restart your modem. If the port forwarding is still not possible, please reset it. Press the reset button on the back of the modem with a pointed object for at least 25 seconds. Then try it again. Greetings Daniele
bergfrieden Hello, I see the Bridge-Mode but not IP-forwarding, and the connection is not working After ohne hour. Many thanks for your support.
