@bjkang , Welcome to the community!
We have measured your line and your modem is still offline. We will provide you with a technician. You will be contacted by us to make an appointment.
In the meantime we ask you to check the antenna cable and the terminals for breaks. Is everything plugged in tight? Is it loose? Is the socket all right?
Greetings
