dbchiem Hi, I ordered a upc connect box but unfortunately, the provided cable is not compatible. I attached the picture of the socket. I think this might be a fiber line? How should i go with it? Does upc support this type of socket? Thank you.
Daniele_Sunrise @dbchiem , Welcome to the community! The correct can would be these. If you don’t have a can, please contact your landlord so he can give us the order to install a can. Greetings Daniele
