@GC9437_69 , If your modem is set to IPv4, you can set it to bridge mode for example. Then you can connect your own router with WIFI6 and more.
If you only use AccesPoints I would not switch to bridge mode.
If the devices are compatible with mesh, etc. you have to read the manual of your own device what the requirements are.
Greetings
