Hi. I was trying to find a way to block at home access to the tiktok. Unfortunately Connect Box router has no simple way for doing this. Could you please help me finding a way to protect my kids and their guests from this cancer?
Thank you for the clarifications. That would explain why I could not find needed functions. I thought it is somehow possible with the Advanced Settings/Security/__IP and Port filtering …or soemthing like that.
If you want to block Sites oder Services, you have to use your own router capable of that.
You can switch den ConnectBox to the bridgemode an use your own router behind it, where you can block sites or services.
