gregoire
Thanks, that explains the situation clearly. As I understand, you are bypassing the official hardware completely by cloning the credentials of your Connect Box 3 Fiber with your custom equipment.
Be aware that Sunrise only allows and supports the original Connect Box 3 Fiber on their XGS-PON network. I cannot help you any further with this and Sunrise will likely not offer any support for it either. The upcoming change in two weeks will probably be an automated backend update. This could potentially affect your customized setup if the network profiles or authentication methods are being realigned.
You should probably keep the official Connect Box 3 Fiber ready just in case, as you might need to reconnect it to restore your connection if the migration impacts your setup.
If you still need more details regarding your specific line, you would have to contact (0800 707 707) directly. But as mentioned, I am afraid that you will only get support for the official hardware and you probably won’t receive any information with your custom setup.
