I am experiencing a very specific routing issue and am hoping to get some technical insight or assistance from the Sunrise support team.
The Setup: I have a home server running at my house. It is configured correctly, and I can access it from the outside world (mobile networks, other ISPs, different cities) with absolutely no problems.
The Problem: The only place I cannot access my server from is my neighbor’s house. My neighbor is also a Sunrise customer. When we try to reach each other’s public IP addresses, the connection drops, and a traceroute/ping results in a “Destination Host Unreachable” error.
The Technical Details: Because we live right next to each other and are both on Sunrise, I checked our public IP addresses and noticed they are extremely close. To protect our privacy, I won’t share the exact addresses, but they look like this:
Because our IPs are in the exact same IP range/subnet, it seems like the traffic is failing to route back out. It behaves exactly as if there is Layer 2 isolation (client isolation) active on the local node/CMTS, preventing two Sunrise modems on the same subnet from talking to each other directly.
My Questions:
Is client isolation active by design between Sunrise customers who are provisioned on the same local node/subnet?
Is there a routing configuration on the Sunrise side that can be adjusted so our traffic successfully routes between our two connections?
Thank you in advance for any technical assistance or insight you can provide!
