Hi,
I got the Connect Box Fibre 3 from Sunrise, and I’d like to change the LAN network ID since I have many reserved IP addresses.
By default, the box uses the 192.168.1.0/24 subnet, and I would like to use 192.168.100.0/24 instead — meaning I want to change the LAN IP address of the box from 192.168.1.1 to 192.168.100.1.
I looked through the web interface but couldn’t find any way to change the network ID or the LAN IP address.
Is there any way to change the LAN network ID on the Connect Box Fibre 3?
Thanks in advance for your help!
