hello JGP001
Port 1, 2 and 3 of the Connect Box 3 FIBRE only support 1GBit/s. The only port to support 2.5Gbit/s is port 4.
In order to have more then 1Gbit/s your hardware needs to support a faster connection too. If you don’t have a 2.5Gbit/s NIC installed you will not get the download speed as offered.
2.5Gbit/s USB adapters might work, but there’s no guarantee, they will offer full speed. A lot depends on the USB port, the adapter itself and the drivers used. While testing a USB adapter, I got results ranging from 300Mbit/s up to 2.3Gbit/s.
Cables cat5e or better are required for 2.5Gbit/s.
If logging out and back in doesn’t work, try to uninstall the app and install it again.
hope this helps
